I2C Multi-master problem
rsweitzer
Posted on January 07, 2013 at 17:01
I'm connected to a device that wants to be master probably 99% of the time. There is a small % of time I need to be the bus master.. Whenever I check the BUSY bit in SR3 the bus is always busy because the device is transmitting. Does anyone have some example code or algorithm that can show me how to arbitrate and take control of the bus?
0 REPLIES 0
