I want to program multiple stm8s microcontrollers at a time. Any programmer device available which is programmed at a time 8 or 16 controllers.
‎2021-02-16 9:21 PM
‎2021-02-16 11:50 PM
What you are looking for is a so called gang programmer. One example is the GangPro from Elprotronic, another one could be the Flasher ATE from Segger.
Good luck!
/Peter
Good luck!
/Peter
