how to make shift bits (asm STVD) , example: 1<<0|1<<3|1<<4
s1975
Posted on July 31, 2013 at 21:45
example:
ld A, 1<<0|1<<3|1<<4
it isn't compiled as it is correct to make record for the STVD assembler?
fggnrc2
Posted on August 01, 2013 at 06:14 Hello user assembler shift operators syntax is different from the C one. The right syntax to load A with the result of your expression is:
LD A,#{{1 shl 0} or {1 shl 3} or {1 shl 4}}
BR EtaPhi
s1975
Posted on August 01, 2013 at 10:46
thank you, compiled
