danielfischer9
floating point library
  • June 23, 2010
  • 1 reply
  • 1733 views
Posted on June 23, 2010 at 07:25
I have to use floating point functions in my application; sqrt, sin, cos, atan.
I have included <math.h>, so the source files compile.  I am using STVD with the Cosmic toolset.
How do I tell the environment to link the floating point library? If I do nothing, the linker complains about not finding sqrt, sin, cos, atan.
I guess I must use libfs0.sm8.  Please provide step by step instructions on how to get to the dialog where I must type in the name of the library.
Thanks.
Daniel
    1 reply
    danielfischer9
    Posted on June 23, 2010 at 08:30
    I found it.
    Project/Settings/Linker Tab (by clicking <> until the tab is in view, then select it)/Select Standard Libraries.
    Daniel
