ADC Channel Measurement Using Internal Reference
Brian1
Is it possible to use the ADC to measure the voltage on an external pin and use the internal reference at the same time? I have a product that is direct connected to battery, so my external reference voltage is variable. I'd like to use an external channel to measure a voltage, but use the internal reference. Are there any examples that exist for this?
Vyacheslav Azarov
In simplest form you can use this formula: Vrin = Vref * Dain / Dref , where Vrin - real input voltage, Vref - known voltage of reference source, Dain - conversion result of analog input , Dref - conversion result of reference source voltage.
