SetupSTM32Cube Programmer V2.10.0 refuses to exécute using M1apple with OS X12.3.1 (Monterey). Did someone experienced that and fixed it PS :Of course the program is authorised to open Best regards` Patrick.
pBoit.1
Sara BEN HADJ YAHYA
Hello @pBoit.1​ ,
Thanks for your feedback,
Please check if the jre folder is found under STM32CubeProgrammer.app Package Contents. If it is not there, please apply the following:
- Copy the jre folder from the downloaded en.stm32cubeprg-mac_v2-10-0
- Open CubeProgrammer install folder
- Right click on STM32CubeProgrammer.app and select "Show Package Contents"
- Paste the jre folder
If this didn't help could you please try to re-install CubeProg using CLI
$sudo xattr -cr ~/SetupSTM32CubeProgrammer-macos.app
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
Sara BEN HADJ YAHYA
Hello @pBoit.1​ ,
Sara.
