I am using the sensortilebox MKSBOX1v1. Is there an ioc file where the pinout matches the hardware? Is there one with the BLE, X-CUBE-AI software packs?
‎2021-06-27 9:41 AM
The ioc found in FP-AI-SENSING does not match. There is no ioc file found in FP-AI-CTXAWARE1. I just want to change the Keras Model for something very similar to the ASC example.
- Labels:
STM32CubeMX
‎2021-06-29 1:41 AM
Hello @Community member​
Thanks for your post,
Actually, the only ioc file available using MKSBOX1v1 is under CubeMX application, Board Selector and enter in the research : STEVAL-MKSBOX1V1 to access to the project generated, unfortunately, the L4R9ZIJx does not support BLE MWs, for that reason you will not find it in the ioc file configured by CubeMX.
You can add Cube AI and Cube BLE packs to that ioc file in this case to obtain your request.
Hope my answer helped you,
Khouloud
‎2021-06-30 10:44 AM
