2026-06-03 6:57 AM
I am using STM32CubeIDE/CubeMX with Azure RTOS NetX Duo on a custom board and need to integrate a custom Ethernet PHY that is not one of the PHYs natively supported by CubeMX. I need to add MXL86110I-AQB-R eth phy.
I would like to understand the recommended procedure for adding a custom PHY when using NetX Duo.
My questions are:
