Ctrl+Space does not show documentation
daviddavid9
How can I get STM32CubeIDE to show proposed function documentatioin when I press Ctrl+Space? For example, if I type "HAL_UART" and press Ctrl+Space, it shows many proposed functions. How to I get it to show the documentation from these functions. That is, the comments in the *.c and *.h source files for the proposed functions. Other C/C++ IDEs show it, but I can not get STM32CubeIDE to show it.
Hovering over the function name will show the comments.
F3 will jump to the definition.
daviddavid9
Hi, thanks for quick reply. Hovering or F3 only works once I have selected a function from the popup window with proposed functions. What other IDEs do, is they will show the function documentation in the small popup window so as I navigate with up/down arrow key to the suggested functions, I see documentation for each. This makes it much easier, seeing that most of the time I do not know what exactly the suggested functions do. For example, if a delay function is msec or usec.
You're going to have to accept subtle differences between workchains. I don't buy the argument that all other IDEs behave one way and STM32CubeIDE behaves another. What other IDEs are you referring to?
