STM32WB55 custom UID
miguekun
UID is set at factory for all products?
Wholesale ICs comes already programmed? I need to repair some machines and IC needs to have same UID as replaced.
The UID can't be set or changed. (That would make it non-unique.)
Andrew Neil
Yes, There is a UID built-in to the STM32:
https://community.st.com/t5/stm32-mcus/how-to-obtain-and-use-the-stm32-96-bit-uid/ta-p/621443
If you don't want to use that UID, you will have to adapt your code to take its UID from another source.
