Stack BLE random crash on STM32WB
JSalv.1
I have an STM32WB that is configured in central, it connects to 8 devices in peripherals mode at the same time. This configuration works well, but from time to time the BLE stack does not respond, I see 8 peripherals disconnected and I do not receive any event from the central stack. When I try to reconnect on the central side, the stack does not respond.
Have you ever had feedback on this kind of problem?
Sincerely,
Remy ISSALYS
Which stack and version are you using? Did you tune the connection interval for each connection?
Best Regards
