Question : I'm using stm32 lorawan in a project with a smart meter, my problem si when a use the PB6 pin (uart) the kit doen't work all the time but with the PA9 all work fine is it normal ?
Thx for help
Options
2021-06-16 7:38 AM
Options
2021-06-16 7:45 AM
Ok, I don't think you're really explained that in enough technical detail for it to be solved.
You'll need to debug the design and the code to understand why it doesn't work properly.
