2024-07-15 10:08 PM - last edited on 2024-07-16 6:45 AM by Peter BENSCH
Hello
I want to use PER test using Nucleo-WB55RG
So, I followed the procedure in git-hub, but TX does not work.
I don't know what the problem is, please help me
2024-07-24 12:21 AM
Hello @JACK6
Can you give more details (What GitHub repository, what is the example that you have used, some more details also will be helpful). I've personally tested this using the first demonstration of this example.
Best Regards.
STTwo-32
