Hi everyone, I have to implement radio test on STM32WB55CG based on possibility to manually set signal power and frequency, switch signal on and off. Could you advice me how can this be achieved using some exist coprocessor binary or any other way?
Gennadii_Votiov
In examples I got familiar with RF low level access is controlled by some exact coprocessor firmware. Existing coprocessor binaries provide some higher level of abstraction that seems to not include forcing signal with exact characteristics. Do I missing something or is there any other approach to start continuous signal generation with specified power and frequency?
Remy ISSALYS
In order to perform RF test, you can use STM32CubeMonitorRF tool available here:
https://www.st.com/en/development-tools/stm32cubemonrf.html
Best Regards
4 REPLIES 4
Remy ISSALYS
Best Regards
Javier1
Principal
As far as i know ST doesnt want you to thinker with the M0+ core, thats why they offer 0 doumentation and only supply already compiled binarie files.
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
Thank you, at first glance I missed that STM32CubeMonitorRF provides possibility to do the low level tests as we need but actually it is possible with Phy_802_15_4_Cli FW for CM4 + stm32wb5x_Phy_802_15_4_fw.bin for CM0 interacting with STM32CubeMonitorRF
Remy ISSALYS
In order to do radio test for BLE, using Direct Test Mode (DTM), you should use stm32wb5x_BLE_HCILayer_fw.bin coprocessor binary available here:
https://github.com/STMicroelectronics/STM32CubeWB/tree/master/Projects/STM32WB_Copro_Wireless_Binaries/STM32WB5x
Best Regards
