Error: -- Reserved -- when installing wireless stack after installing auth key
Baseline:
I can install FUS and Wireless Stack binaries via SWD just fine. I can re-install the wireless stack without a problem when no auth key is programmed.
My problem:
As soon as I install an auth key, installing/updating the wireless stack results in an
I recon this is because the FUS now also checks wireless stack binaries against the user auth key. In this situation I would expect the error to be: FUS_STATE_IMG_NOT_AUTHENTIC
I tried signing the wireless stack binary with my auth key (using the prepareimage tool). But I'm quite sure I did something wrong, because when I install that signed binary I actually receive the FUS_STATE_IMG_NOT_AUTHENTIC error.
So the second question is:
How to sign an STM binary with a user auth key?
AN5185 states in Chapter 4: "The instruction to sign a binary with user authentication key are provided in STM32CubeProgrammer user manual." But I only see the commands to write they key via the bootloader.
