TouchGFX image convertor
lzlin
We are using TouchGFX for LCD UI design.  It seems that the generated c files for image have reverse-ordered 16-bit data.  We have to revert the image at run-time.  Is there a way to revert the 16-bit order during image converting?
LouisB
Hello Izlin,
By reverse, you mean little/big endian ? If so, no there's no way to switch edianess.
What is your use case ?
BR,
Louis B.
Louis BOUDO
ST Software Engineer | TouchGFX
