2022-12-12 2:43 AM
I'm currently working on the STM32H753I-EVAL02 with the 5.7" parallel RGB 24 screen.
Now, I would like to buy a bigger screen with higher resolution (e.g. 7/8" - 1024*600). With this configuration, it's recommended to use LVDS rather than parallel RGB.
So, for that, I will need a new controller board that takes for input parallel RGB 24 (from the motherboard) with a 50 pins IDC connector and for output, LVDS.
After long research, I don't find any controller board that matching this case.
Does anyone have some references (or just one ! :D) ? Or does someone have never changed a parallel RGB touch screen by an LVDS ?
