STM32F429 DISCOVERY LTDC 640 * 480 8BIT SDRAM INTERFACE
naser moravej
Hello everyone.
I want to show a picture from external SDRAM in 8bit mode using FMC with stm32f429zi discovery board.
As long as I use FMC in 16bit mode with 16-bit byte enabled, I can show a picture but as soon as I uncheck "16-bit byte enable", even in 16 bit mode, everything get ruined.
waclawek.jan
Where do you uncheck that? What does it mean in terms of FMC registers' content? What does "even in 16-bit mode" mean?
Don't you exceed the memory's bandwith? Read AN4861.
