2022-02-17 12:06 AM
How can I adjust font kerning in a textArea (or anything else) string?
2022-02-17 3:42 AM
Hello VLau,
The simplest way to adjust kerning would be to modify the properties of your font itself, to make it compliant with your needs. You can refer to this link and this one also, if you need more info about how to use fonts in TouchGFX Designer.
/Osman
2022-02-17 3:42 AM
Hello VLau,
/Osman
