2021-04-29 7:59 AM
I'm trying to print the string. What is that I'm missing?
This is my func :
void Screen1View::UpdateWildcardTexts(char* a)
Unicode::snprintf(textArea1Buffer,10,"%s",a);
textArea1.invalidate();
}This is how I test it :
void Screen1View::setupScreen()
Screen1ViewBase::setupScreen();
char a[16] = "string";
UpdateWildcardTexts(a);
2021-04-29 2:21 PM
touchgfx::Unicode::snprintf only supports the %s format with UnicodeChar arguments. You should use touchgfx::Unicode::strncpy instead to fill the buffer with your char array.
touchgfx::Unicode::strncpy(textArea1Buffer, a, 10);If you really want to use snprintf, convert it to a UnicodeChar first.
void Screen1View::UpdateWildcardTexts(const char* a)
touchgfx::Unicode::UnicodeChar b[10];
touchgfx::Unicode::strncpy(b, a, 10);
touchgfx::Unicode::snprintf(textArea1Buffer,10,"%s",b);
}Sidenote: @Martin KJELDSEN I see that anchor links in tgfx documentation still don't work =)
2021-04-29 2:21 PM
2021-04-29 11:16 PM
Thank you for your answer. I tried to use strncpy(), but I got fallback character even I wrote A-Z into Wilcard Ranges. Now I just wrote a-z into Wilcard Ranges and I could see the "string".
