Please contact us regarding touchgfx lcd. Normally, the screen is fine, but if you change the screen or use an animation timer Image is sometimes cracked. We would appreciate it if you could tell us how to solve it. See the video work hard
GGIL.1
Alexandre RENOUX
Principal
What board and what display are you using ?
What version of TouchGFX and what IDE are you using ?
As mentioned in your previous post, please provide more information.
/Alexandre
i use stm32f469ig board , touchgfx 4.13 version and stmcubeide1.3.0 version
F469-Disco I presume ? Do you use the screen of the F469 or you changed it ?
If you changed the screen, there might be many different reasons why you have this issue.
Try to make sure that your board-display link is working correctly by first simply displaying a box and see if there are issues even at that stage.
/Alexandre
