Obtaining Timestamps using Unico GUI
RS1
Please suggest how timestamps can be logged onto a text file using the Unico GUI
Eleon BORLINI
Hi @RS​ , the timestamp is not directly available through UNICO GUI, but you can go back to the time value starting from the ODR you set for the data output --> 1/ODR will be the basic time base. You can set the T0 according to your need. Regards
