Go back to last screen
Hi
Is there a solution to go back to the last screen?
For example you go from any screen to the SettingsScreen and after you have set all settings you would like to go back to the last screen.
Dejan
Martin KJELDSEN
Chief III
Hi @Dejan Nedeljkovic​,
I'm about to leave but i've done this for someone on the forum before - Check this out. I don't recall which version it is, but i'm sure you'll figure things out :)
http://sw-center-st-com.s3-eu-west-1.amazonaws.com/touchgfx/TouchGFX/Community/gotoStack_example.zip
It involves pushing function pointers (to transition methods) onto a stack whenever you transition to a new view. And you can then pop + call those functions when through a method you call when you press your back button or something similar.
/Martin
4 REPLIES 4
Martin KJELDSEN
Chief III
/Martin
Hi @Martin KJELDSEN​
Thank you for this example.
I'll try out as soon as possible.
Dejan
Sandy.Dahl
Hi @Martin KJELDSEN​ !
I don't think this solution will work queit as smooth when transitioning screens via the designer. Correct? Since the base-classes don't use the functions in frontend application?
Kind regards,
Sandy
Correct. This example is not designer compliant because of code generation
