Wrong CRC on STM32F3 at byte-level
elettromanu
Posted on April 08, 2015 at 13:09
I'm trying to
use
the
CRC
peripheral on STM32F3
to calculate the
CRC
at
byte-level
but I can not
get the same result
as
indicated
in
application note
AN4187
The
following snippet of
code should
return a
CRC
equal to
0x4C
(according to AN4187) instead
I get 0x80
Where
is the error
            CRC->INIT = 0xFF;
            CRC->CR = CRC_CR_POLYSIZE_1;
            CRC->POL = 0xCB;
            CRC->CR |= CRC_CR_RESET;
            CRC->DR = 0xC1;
p.s. The
peripheral
clock has been enabled.
Many thanks in advance for your help.
#stm32f3-crc
Posted on April 08, 2015 at 15:58
Perhaps you want
*((uint8_t *)&CRC->DR) = 0xC1;
elettromanu
Posted on April 09, 2015 at 09:54
That's right!
Clive
thanks
for your
invaluable
support!
Best Regards
