Merging SBSFU(.hex) and Application(.sfb) into single hex file not working
Tarun
Hi Community,
I'm in a process to combine the SBSFU and Application file into single intel hex using srec_cat.exe doesn't work.
srec_cat Application.sfb -binary -offset 0x08010000 -o APP_Offset.hex -intel
srec_cat STM32G0B0RE_SBSFU.hex -intel Application.hex -intel -o Combined_App.hex -intel
Combined_App.hex always executing in bootloader and not jumping to application after several power cycles.
Is it because of encryption/signing?
Can anyone suggest better approach to deal with this?
STea
Hello @Tarun ,
Can you give more information on the error message you get on the terminal and could you give more details about the process you followed to install the combined app . Lucking a lot of context to further guide you throw your manipulation .
BR
