Zero Jitter ISR for STM32F051
Options
2013-08-05 8:00 AM
Posted on August 05, 2013 at 17:00
On STM32F051 I am trying to implement zero jitter interrupt servce routine for TIM6. I understand in Cortex-M0 architecture, there is a way to set higher IRQ latency to achieve zero jitter. I am not able to locate the registers for this value in STM32F051. I am not sure if the feature is implemented by ST.Can somebody guide me. Thank you #arm32-interrupt-latency
Options
2013-08-05 8:43 AM
Posted on August 05, 2013 at 17:43
Higher latency?
The NVIC should allow you to program a priority level associated with an interrupt, and this should allow one interrupt to preempt another.
