Would it be possible to connect the STM32F769I-DISCO board to a 4G communication module?
LleytoN
Hello!
I own an STM32F769I-DISCO board and I have just read that it is already possible to use a serial Wi-Fi module (called ESP8266-01). However, I have been wondering for some days whether it is also possible to use a 4G communication module with this board.
I truly thank you in advance for your help!
Lleyton
Sure it has a shield connector, could add one there.
Probably would need a better power-supply, or one directly to the 4G modules, and most cellular modems can pull several amps under certain conditions.
Hello!
Thank you very much for your answer!
Therefore, would you know some examples of 4G compatible modules?
Best,
Lleyton
