Voice active detection of Speex encoding on STM32F4.
Options
‎2014-06-18 3:07 AM
Posted on June 18, 2014 at 12:07
Hi all,
I develop the SPEEX encoding on STM32F4 follow the application note : ''Vocoder demonstration using a Speex audio codecon STM32F101xx and STM32F103xx microcontrollers'' and it's ok. I can play realtime with Speex encoding and decoding. Look at Speex, it have the opption: VOICE ACTIVE DETECTION and it always go with VBR (variable bitrate operation) opption. Now, my task is detect voice and i think about SPEEX. Have anyone know the value or flag that show the input stream is Voice or noise... Thanks in advance.PS: I see the name of author of application note is Joys. If he can read it, please help me.Regards,Nhan
Options
‎2014-07-22 1:29 AM
Posted on July 22, 2014 at 10:29
Hi Nhan,
I'm sorry, I couldn't help you but I think you can help me :)I have just tried to implement the same vocoder solution mentioned in that Application Note. However, I took several errors and I couldn't make it. The error I struggle now is that when it calls the speex_decoder_ctl in Speex_Init(), it falls to HardFault_Handler(). Can you help me about this.Besides, I am curious about something, STm32f101 is Cortex-M3 but STM32F4 is Cortex-M4. Does the code written in assembly especially for M3 work on M4?Any help will be appreciatedEdit: I figured out that eventhough speex_encoder_init() function works like a charm,speex_decoder_init() function returns Null. That's why programme always goes HardFault_Handler().I couldn't solve it yet and I am still waiting for your help.Best RegardsKahyaOptions
‎2014-09-11 12:44 AM
Posted on September 11, 2014 at 09:44
Hi Kahya,
Sorry about too lately feetback. You should try to change stack size and heap size to pass Speex_Init(). At the first time, I didnot know the vocoder still run on cortex M4, but I try to put it, and it's ok, my project was finish.I hope to help you although 2 month pass. :) Good to know you.Regards,Nhan
