uVision514: cannot open source file *.h
enmirc
Posted on September 11, 2016 at 07:47
Hi guys,
1. compile proj. Keil51 uVision: ->   error: #5: cannot open source file ''MCode.h''
2. MCode.c
   #include ''MCode.h''
3. Options for target -> c/c++ -> path ../user
4. user (MCode.h) etc..
Q: it seems everything is ok, but why compiler does not find MCode.h ??
thank you for the answers ..                                br M.
5 REPLIES 5
Posted on September 11, 2016 at 23:19
Because it is not being told to look in the right places, you will need to provide an adequately complete list in (3) for it to be able to find the files. You could also try the < > form if you are absolutely sure the search paths list is correct/complete. I'd start by reviewing the project.
enmirc
enmirc
Posted on September 15, 2016 at 09:17
hello Clive1,
I attached my project, could you be so kind
and check what is wrong ? I did as you said
but uVision5 refuse to include my file ..   br M.
slimen
Posted on September 15, 2016 at 12:04
Hi mickey,
Issue due to the file name defined with space ''MCode .h'' !
You should remove the space between MCode and (.h).
Make sure you have the include paths specified properly, clean Target, then rebuild all target files.
enmirc
Posted on September 17, 2016 at 12:03
tnx a lot, o God I need new glasses ..
