Transmit Array via SPI use stm32cube
contactst
Posted on June 19, 2016 at 08:52
The original post was too long to process during our migration. Please click on the attachment to read the original post.
Walid FTITI_O
Senior II
Posted on June 20, 2016 at 11:43
Hi cheetu.lee,
I recommend you to take a look to the '' SPI_FullDuplex_ComIT'' example in
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef4.html
and compare the code there with your code. The example at this path: STM32Cube_FW_F4_V1.12.0\Projects\STM32F4-Discovery\Examples\SPI\SPI_FullDuplex_ComIT
You should ensure that you are wiring correctly the connection cables.
-Hannibal-
