Timer1 capture data
imanpakii
Posted on December 22, 2012 at 02:07
Hi all
i run timer 1 in capture mode and i want to know how can i reset the counter.
for example i capturing signal and store it  in an array. The counter counting from 0 to 65535 and every time edge comes in interrupt routine i read counter value and subtract it from last value but sometimes  i need too rest counter value how can i do that please help me Thank you
4 REPLIES 4
Posted on December 22, 2012 at 04:05
Can't you just write to the TIMx->CNT register? But if you're just computing a delta between two readings I'm not sure why you'd need to reset it.
imanpakii
Posted on December 22, 2012 at 04:50
Thank you for your fast reply
because sometime my signal stream off and i want to clear counter in this time.
But i don't know how can i clear counter reg.
Posted on December 22, 2012 at 04:56
Try writing zero to it, it is documented to be a R/W register.
imanpakii
Posted on December 22, 2012 at 05:11
Thank you Clive1
 TIMx->CNT =0;
Arg1=
 TIMx->CNT;
was work.
Thank you for your help. It's helpful as usual.
