SVC_Handler fails badly - hardfaults
‎2013-09-06 10:20 AM
Below is the code for asm SVC handler straight from an example by ARM:
SVC_Handler STMFD sp!,{r0-r3,r12,lr} ; Store registers. LDR r0,[lr, #4] ; Calculate address of SWI instruction and load it into r0. BIC r0,r0,#0xff000000 ; Mask off top 8 bits of instruction to give SWI number. ; ; Use value in r0 to determine which SWI routine to execute. ; LDMFD sp!, {r0-r12,pc} ; Restore registers and return. END ; Mark end of this file. And i get Hard Fault failure on LDR instruction . wtf.. Any ideas? I've seen same code sequence in many examples of the same SVC handler, and in other code.- Mark as New
‎2013-09-06 10:27 AM
What's the value in LR when it fails? I'd imagine it's a magic value indicating which stack was used? 0xFF??????
The stack push/pop aren't balanced.Up vote any posts that you find helpful, it shows what's working..
‎2013-09-06 2:41 PM
Is the stack aligned to a word boundary?
Jack Peacock- Mark as New
‎2013-09-09 12:17 AM
>What's the value in LR when it fails? I'd imagine it's a magic value indicating which >stack was used? 0xFF??????
Yes, the magic. >The stack push/pop aren't balanced. Yes, i see, copied wrong. But thats not the problem (at that moment)- Mark as New
‎2013-09-09 1:00 AM
Sorry i just correct a little my original post, _but__ this is just because I was doing 4 things at same time, the copying to forum went wrong.
name SVC_Handler
public SVC_Handler
section READONLY:CODE
SVC_Handler STMFD sp!,{r0-r3,r12,lr} ; Store registers. LDR r0,[lr, #-4] ; Calculate address of SWI instruction and load it into r0. BIC r0,r0,#0xff000000 ; Mask off top 8 bits of instruction to give SWI number. ; Use value in r0 to determine which SWI routine to execute. ; LDMFD sp!, {r0-r3,r12,pc}^ ; Restore registers and return. END I'm puzzled with the instruction . LDR r0,[lr, #-4] ; ; and yes its -4 for ARM not Thumb As clive1 pointed out, lr in when in SVC contains a magic value, the magic contained in only last 4 bits i think (saw in manual, can't recall page now..) So how is the above suppose to calculate the address of the SWI instruction and load it, that's magic to me. But i don't do ARM asm programming :\ May be this does not apply to CortexM3 at all? I have not found a more CM3 specialized example.. By the way, LDMFD sp!, {r0-r3,r12,pc}^ The ^ is 'kinda' important as i read, yet my asm compiler - IAR Systems - does not accept it..- Mark as New
‎2013-09-09 1:03 AM
> Jack Peacock Jack, now I do this right at start in my hal init: SCB->CCR |= SCB_CCR_STKALIGN; Still that SVC of mine promptly hard faults at same place ...- Mark as New
‎2013-09-09 2:37 AM
clive1, and the magic in LR is
0xFFFFFFF9. STM32F10xxx prog manual, p40: EXC_RETURN[3:0] = 0x09 = 0b1001. = ''Return to Thread mode. Exception return gets state from MSP. Execution uses MSP after return.'' Do you know how that LDR instruction is suppose to do what the comment says it should ..? Don't know if it explains the hardfault either ...- Mark as New
‎2013-09-09 4:55 AM
http://www.arm.com/files/pdf/cortex-m3_programming_for_arm7_developers.pdf
‎2013-09-09 5:29 AM
Yea that's it... Pretty much same as my HardFault_Handler I copied else where, urghhg..
Thanks- Mark as New
‎2013-09-09 5:43 AM
void SVC_Handler(void)
{ __asm volatile( ''TST LR, #4 \n'' ''ITE EQ \n'' ''MRSEQ R0, MSP \n'' ''MRSNE R0, PSP \n'' ''B svc_handler_c'' ); } void svc_handler_c (unsigned int * svc_args) { // ... svc_number = ((char *)svc_args[6])[-2]; // .... } thanks for pointed to that doc...
