2026-01-27 12:51 AM
When merging GFX and AI projects in stm32n6, once the camera image is written to the address LL_Buffer_addr_start(&nn_in_info[0]) (hereinafter represented by nn_in), the system freezes.
Upon investigation, it was found that there is a partial overlap between the memory allocation in network.c and the memory in GFX. Could the freeze be related to memory or the XSPI2 bus?
What modifications should be made?
The network uses the st_yolo_x_nano_480_1.0_0.25_3_st_int8.tflite file from the routine STM32N6-GettingStarted-ObjectDetection-main.
Thank you all for your replies
