Inference Blocking on LL_ATON_OSAL_WFE() with ThreadX
I am working on implementing an object detection application for the STM32N6570-DK, starting from the reference projects:
I'm encountering a blocking issue when implementing the inference pipeline:
During debugging, I found that the inference execution blocks indefinitely at LL_ATON_OSAL_WFE() on line 105 of Appli\App\Src\app_nn.c. The code is stuck in the following loop:
static void NN_RunInference(void) {
 LL_ATON_RT_RetValues_t ret;
 do {
 ret = LL_ATON_RT_RunEpochBlock(&NN_Instance_od_yolo_x_person);
 if (ret == LL_ATON_RT_WFE) {
 LL_ATON_OSAL_WFE(); // <-- Blocks here
 } while (ret != LL_ATON_RT_DONE);
 LL_ATON_RT_Reset_Network(&NN_Instance_od_yolo_x_person);
I've reviewed similar posts in the community
, but it didn't resolve my issue.
Questions:
What could be the issue that blocks inference indefinitely at `LL_ATON_OSAL_WFE()`, and how to fix it?
Source Code:
My current implementation is available at: https://github.com/Foahh/stm32n6-ai-camera.git
FoahhBest answer
The problem fixed by adding the code below.
void HAL_CACHEAXI_MspInit(CACHEAXI_HandleTypeDef *hcacheaxi)
 __HAL_RCC_CACHEAXIRAM_MEM_CLK_ENABLE();
 __HAL_RCC_CACHEAXI_CLK_ENABLE();
 __HAL_RCC_CACHEAXI_FORCE_RESET();
 __HAL_RCC_CACHEAXI_RELEASE_RESET();
void HAL_CACHEAXI_MspDeInit(CACHEAXI_HandleTypeDef *hcacheaxi)
 __HAL_RCC_CACHEAXIRAM_MEM_CLK_DISABLE();
 __HAL_RCC_CACHEAXI_CLK_DISABLE();
I compared it with other projects, and it looks like I forgot to implement something for enabling the CACHEXI.
I found npu_cache_init() calls HAL_CACHEAXI_Init() and the latter one internally calls HAL_CACHEAXI_MspInit(),
but HAL_CACHEAXI_MspInit() is not implemented in my code.
FoahhAuthor
Update: I initially used STEdgeAI 3.0. I later switched to STEdgeAI 2.2, but the issue persisted.
FoahhAuthor
 .text.NPU0_IRQHandler
 0x340322d8 0x124 CMakeFiles/Firmware_Appli.dir/.../ll_aton/ll_aton_runtime.c.obj
 0x340322d8 NPU0_IRQHandler
The furthest I’ve been able to debug is that NPU0_IRQHandler (expanded by ATON_STD_IRQHandler macro in ll_aton_runtime.c) never fires.
FoahhAuthorBest answer
