2016-06-13 4:53 AM
No peripheral enabled.
Only mcu is mounted and power is feed from power supply directly.Current is nearly 170 uA at MSI 1Mhz low power sleep mode.but cubeMx says 65 uA.In other modes, current is almost 100 uA more than the cubeMx tool present.All clock except MSI is off.Am i missing something?2016-06-13 6:04 AM
Hi embedholic,
ou find a difference betwen the Power Conusmption Calculator values and datasheet value ? Please share you .ico file. -Hannibal-
