stm32l432 / openocd
Geoffrey1
Posted on August 02, 2016 at 15:12
I'm starting a project with the stm32l432.   In order to use openocd I had to tweak the sources slightly.
1)  Picked up a version that supports other stm32l4 processors  from  https://github.com/arduino/OpenOCD/
2) modified flash/nor/stm32l4x.c at line 620 adding a case for the device id
      case 0x415:
      case 0x435
3) You may need to modify stm32l4x.cfg   adding a case for _BSTAPID1 0x06435041  -- not sure since I did this first and found I had to make the mod at (2).
In any case, with these mods I was able to use openocd to program and debug (with gdb) my stm32l432 nucleo 32 board.
Geoffrey
Nesrine M_O
Lead II
Posted on August 02, 2016 at 15:40
Hi Geoffrey ,
Thank you for sharing your findings.
Hope that this will be helpful for forum users.
-Syrine-
qwer.asdf
Posted on August 02, 2016 at 16:43
Thanks Geoffrey, can you please send your patch to the official OpenOCD developers? Here's the patch sending guide -
http://openocd.org/doc/doxygen/html/patchguide.html
Geoffrey1
Posted on August 03, 2016 at 18:35
A good idea and thanks for the link, but I confess that the process is a bit more involved than I have time for at the moment.
Geoffrey
