2015-04-29 5:39 PM
In debug mode SCM just reverts to 0 everytime I try to set it. I can set ASCR1 Channels just fine in debug, but my code won't set the channels.
Here's the section that should set these bits RI->ASCR1 |= RI_ASCR1_SCM; RI->ASCR1 |= RI_ASCR1_VCOMP; RI->ASCR1 |= RI_ASCR1_CH_0;If I run this and go into debug they aren't set. But I can manually set VCOMP and CH0. Even though it doesn't seem to actually go into effect. #ri-routing-interface #scm
