2026-01-08 7:40 AM
In my project I've set the SPI clock to 125MHz; with a SPI prescaler value=4 all works good, when I set it to 2 the SPI stops working and ther is no clock signal.
Any helps ?
Thank you
CarloV
2026-01-09 7:31 AM
You're using HAL... maybe try setting the few SPI registers manually ?
2026-01-09 7:34 AM
Put together a minimal working example which someone else can compile and duplicate the issue.
