STM32F7 MPU performance impact?
Posted on July 21, 2017 at 23:36
Greetings,
After reading
http://www.keil.com/support/docs/3777.htm
it seems like a good idea to change the SDRAM attributes via the MPU.  Can anyone comment on the performance impact of enabling the MPU (it's not currently enabled in our application)?
Thanks,
Dave
Posted on July 21, 2017 at 23:52
My take away is that it's better to remap the memory. Uncached SDRAM is surely not very desirable.
I know you can fault an M3/M4 if you access a 64-bit (int or double) using LDRD/STRD that is unaligned, haven't tried the M7, and the M0 is a bigger headache like the old ARM7/ARM9 parts
