2014-05-27 6:05 AM
Hello @all,
does anyone know how the following registers behave when the USB peripheral is used in HighSpeed mode(?): - OTG_HS_GRXSTSR/OTG_HS_GRXSTSP : is it required (or even possible) to read/pop a status when DMA transfers the packets? - OTG_HS_GINSTS: is the RXFLVL flag used in DMA mode? - How is the data flow if DMA is enabled for the peripheral? best regards, bsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
