STM32F407 project on Eclipse oxygen using windows10 64 bit
Posted on June 30, 2018 at 10:53
         I have created STM32F407 projects on eclipse oxygen on my windows 10,64bit. when I am trying build the code ,I am getting below mentioned error.
arm.-none-eabi-gcc.exe-Application Error The application was unable to start correctly (0x0000142) click OK and close the application.
I have already installed GNU ARM eclipse plugin in eclipse->marketplace. I have also download and add bin directory of ARM GNU eclipse package.
How to resolve?
Cyril FENARD
Posted on July 02, 2018 at 10:48
Hi
selvamurugan.t
Why don&39t you take the OpenSTM32 update site of to cross compile your project targeting STM32?
https://www.ac6-tools.com/Eclipse-updates/org.openstm32.system-workbench.update-site-v2/
As information, my side, with Windows Seven, i use Eclipse (Oxygen.3a Release).
Note that there are known issues about Eclipse CDT (9.4.3 in my case) and the setting of the Run configuration (Reset, Halt to be unchecked).
Hoping it helps.
Cyril.
