STM32F4 corrupt memory/damaged MCU
‎2015-08-30 7:53 AM
I've been working on a project on my STM32F4 Discovery for a few weeks now and it's been working fine. Today I connected a OV7670 camera and after uploading the code the discovery stopped working after a while for some reason. I removed all the wires that connect the camera but still it does not work.I try to debug to see what is wrong but when I go into the SystemInit() function the debugger just hangs there and does not continue. The dissasembler just shows nothing after that. What is wrong? I tried a few times to erase the whole flash memory and reprogram but it did not help.I'm using Coocox IDE and STM32F407Discovery with stlink via usb- Mark as New
‎2015-08-30 8:29 AM
So do you actually STEP INTO SystemInit(), at what line of code explicitly does it stop? Is it waiting for a clock to start, a PLL to lock?
Do you have another board to see if it's board/chip specific?Have you looked at the voltages on the board can checked if they are where they should be? ie VDD at 3.0V, VCAPs at 1.25VUp vote any posts that you find helpful, it shows what's working..
‎2016-12-31 1:57 AM
to_deletemr assioma
‌Hi,
Around a year back you have faced this issue, and currently I am facing similar issue. Is it resolved? Can you please help me with the resolution?
Thanks,
Dhaval
‎2016-12-31 9:26 AM
Please try not to reopen old threads where the OP hasn't even bothered to respond to the advice provided.
If a part has been crashed by user code, strap BOOT0 high so it doesn't run and break the debugger interface. The system loader is in ROM/OTP it isn't something that is going to get randomly erased.
