2014-05-07 7:56 AM
stm32f303 debugger is not working
controller
doesnt
power up withusb
connection withlaptop but
wheni
supply external supply of 3v it powers up but debugger still not working.
what
could be the fault?
#stm32f303vct6 #too-vague2014-05-07 8:02 AM
Hi
Might be one of these : Bad USB cable Broken USB port on PC Bad USB connector on STM32 board ST-Link on STM32 board damaged.2014-05-07 8:08 AM
usb
cable is fine.
but
whydoesnt
it powers up??
i
have tried more than one cable2014-05-07 8:22 AM
Hi
Add one more to the list: 3/3.3V regulator on STM32 board damaged2014-05-07 8:41 AM
thanks
!. I powered up controller using external 3v .how
to fix debugger now as its not working now2014-05-08 1:26 AM
Hi
''how
to fix debugger now as its not working now '' I do not think you have conclusively proved it is the debugger that is at fault. The ''stm32f303'' is just a STM32F3 embedded processor. I did not find a specific evaluation board for this part - so I do not know what debugger you are referring to. Is a ST-Link (in a little white plastic case) http://www.st.com/web/en/catalog/tools/FM146/CL1984/SC720/SS1450/PF251168?s_searchtype=keyword2014-05-08 4:28 AM
Ok, so what boards is this, which USB connection are you using, and what debugger are you talking about?
