STM32F108C8T6 - I2C lock-up
Andrew Neil
Posted on October 02, 2010 at 09:54
12 REPLIES 12
Andrew Neil
Posted on May 17, 2011 at 14:09
No - that makes no difference.
Andrew Neil
I take that back - I hadn't applied it to all places where I set a STOP condition
When I apply it to all places where I set a STOP condition - it stops hanging!
John F.
I use the code below to write to an LTC4151. Your application must be similar.
void LTC4151WriteBuffer(uint8_t* pBuffer, uint8_t NumByteToWrite)
  /*!< While the bus is busy */
  while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY))
  /*!< Send START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  /*!< Test on EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT))
  /*!< Send address for write */
  I2C_Send7bitAddress(I2C1, LTC4151Address, I2C_Direction_Transmitter);
  /*!< Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
  //send the reg select COMMAND byte
  I2C_SendData(I2C1, 0);
  /*!< Test on EV8 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
  /*!< While there is data to be written */
  while(NumByteToWrite--)
    /*!< Send the current byte */
    I2C_SendData(I2C1, *pBuffer);
    /*!< Point to the next byte to be written */
    pBuffer++;
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
  /*!< Send STOP condition */
  I2C_GenerateSTOP(I2C1, ENABLE);
The fact you could fix your problem with just 5 NOPs implies a hardware timing restriction which might just be how long it takes the I2C ''engine'' to clock through to the next state.
(Our posts crossed - pleased to hear it's now working.)
