STM32F103 - Timer issue after reset
tarikku
Posted on March 14, 2011 at 01:28
5 REPLIES 5
Posted on May 17, 2011 at 14:27
Does anyone have an idea of what might be causing this?
Should we just guess at what you are doing wrong? or are you going to post the code?
tarikku
Guessing is good, code might be better...
void RCC_Configuration(void) {
      RCC_DeInit();
      RCC_HSEConfig(RCC_HSE_ON);
      HSEStartUpStatus = RCC_WaitForHSEStartUp();
      if (HSEStartUpStatus == SUCCESS)
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        FLASH_SetLatency(FLASH_Latency_2);
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        RCC_PCLK2Config(RCC_HCLK_Div1);
        RCC_PCLK1Config(RCC_HCLK_Div2);
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
        RCC_PLLCmd(ENABLE);
        while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        while(RCC_GetSYSCLKSource() != 0x08)
      else
        while (1)
      /* Enable USART1, GPIOA, GPIOB, GPIOC and AFIO clocks */
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |
                             RCC_APB2Periph_GPIOB |
                             RCC_APB2Periph_GPIOC |
                             RCC_APB2Periph_AFIO, ENABLE);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
      RCC_APB2PeriphResetCmd(RCC_APB2Periph_GPIOA |
                             RCC_APB2Periph_GPIOC,
                             DISABLE);
void initTimer(void)
    TIM_TimeBaseInitTypeDef TimeBaseInit;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    TimeBaseInit.TIM_Period = 35999;
    TimeBaseInit.TIM_Prescaler = 999;
    TimeBaseInit.TIM_ClockDivision = TIM_CKD_DIV1;
    TimeBaseInit.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM2, &TimeBaseInit);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
    TIM_OCInitStructure.TIM_Pulse = 6000;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init(TIM2, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
    TIM_ClearFlag(TIM2, TIM_IT_CC1);
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
    TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE);
    TIM_Cmd(TIM2, ENABLE);
void TIM2_IRQHandler()
    if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET) {
        GPIO_WriteBit(GPIOC, GPIO_Pin_12, (BitAction) 1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_12));
ColdWeather
In void initTimer(void) try to call
prior to init calls like
Yes, you need to move
to earlier in the init routine, so that the peripheral is functional while you are programming it's internal registers.
tarikku
That's done it, thanks a lot
