STM32, Keil MDK-ARM cannot debug, seems to try and run from SRAM
anbeyon2
Posted on September 08, 2010 at 15:27
anbeyon2
Posted on May 17, 2011 at 14:06
Found out what the ptoblem is.
We are using an external watchdog.  pPoduction fitted and alternative part.   If I disable the watchdog circuit I no longer have the problem.
Interesting that it caused such odd things to happen especially in debug mode.
The two parts spec looks more or less identical but there is clearly a difference.
Thanks to all that read my message.
Clive
