SPI, debugging, errors, need help!
Options
‎2012-03-29 1:16 AM
Posted on March 29, 2012 at 10:16The original post was too long to process during our migration. Please click on the attachment to read the original post.
Options
‎2012-03-29 7:00 PM
Posted on March 30, 2012 at 04:00
Just make sure that the circuit is not drawing too much current.. for example LCD backlight ..
or SPI pins accidently/momentatrily shorted to VDD/Gnd. causing the 3.3V to drop...Ths may cause the Debugger to fail. I guess you may have verified that the board is fine by running another firmwareOptions
‎2012-03-29 8:23 PM
Posted on March 30, 2012 at 05:23
Failed to read CPUID for Cortex device
> It seems like JTAG works fail. I suggest check the setting of your J-Link. Can you post more fail information?Simon
