RCC PLL Timeout with -O0
Felix TREFOU
Posted on June 20, 2018 at 18:00
I'm facing a strange problem due to optimization 0.
Actually, my code is working well but when i set optimisation to 'None' the MCU fail in its initialization.
The lines concerned are in stm32l4xx_hal_rcc.c line 839.
the PLLRDY bit never set, is this a known issue?
Felix.
Posted on June 20, 2018 at 18:20
And you're using what tools?
What version of the L4 library specifically?
How much time is it actually waiting?
Issues with L4 code not setting PLLM, ie SystemClock_Config()
Felix TREFOU
Posted on June 21, 2018 at 09:42
Ok that was that, PLLM not set to 1.
I already had a similar problem but the code was crashing before, don't know why it was working under different optimizations level!
Thanks.
