2016-02-06 12:47 AM
Good afternoon for all.
In flat interrupt model of other processors after entering in handler all interrupts will be disabled automatically as normal. For implement nesting you must enable interrupts by himself. The manuals not has explanation about this. How to control this in ARM?Regards. #interrupts #interrupts2016-02-06 4:16 AM
Have you tried the ARM infocenter website for documentation ?
Like this one:http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf
Other Cortex-M vendors include core documentation in their datasheets/manuals, ST leaves the customer on it's own here.2016-02-06 4:20 AM
Hello.
On Cortex-Mx if you need disable iterrupts be shour about that. Cortex M have interrupt priority. In interrupt handler only interrupt with bigger priority can be handled. Read about NVIC. See STM programming manuals correct way to disable interrupts is:__disable_interrupts();
__DSB(); __ISB();2016-02-06 5:51 AM
Thank you.
I know those CMIS functions and had read about NVIC attentively. This very useful features of preemption. And tail-chain, late-arriving optimization also. I seem to understand this mechanism. This is very good, everything is done automatically. A critical sections as usual, via the __disable_irq() and __enable_irq().2016-02-06 7:59 AM
Look what is write in last post abaut disabling IRQ, this same must ne done in any similar situation in critical sections.
This is becose next intruction can be executed before write to coresponding reg or disabling interrupt will be finished.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
