Programming stm32 using another mcu
sudhan j
Posted on February 07, 2017 at 10:06
My project include two MCU with nrf51822 and STM32. I'm upgrading STM32 application firmware by nrf51822 using UART. I'm very new for stm32 world so i don't know what and all modifications need to be perform at stm32 side. Kindly give me some suggestions for solving this problem.
Max
Posted on February 09, 2017 at 12:09
What
Turvey.Clive.002
was suggesting is that you may not need to write your own bootloader to program the STM
You may want to use the one already built-in. Look at
http://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD001675pdf/files/CD001675pdf/jcr:content/translations/en.CD001675pdf
and
http://www.st.com/content/ccc/resource/technical/document/application_note/51/5f/03/1e/bd/9b/45/be/CD00264pdf/files/CD00264pdf/jcr:content/translations/en.CD00264pdf
for details.
If you still need to make your own, here is an example using the HAL:
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-iap-usart.html
there are many older examples on ST web site using the STDLIB if needed.
best regards,
Max
5 REPLIES 5
Oliver Beirne
Posted on February 07, 2017 at 13:47
Hello
I have moved your thread to the
https://community.st.com/community/stm32-community/stm32-forum?sr=search&searchId=08430c38-4a42-4d27-830f-574440b914b8&searchIndex=0
‌ where someone should be able to assist you.
Posted on February 07, 2017 at 18:20
ST provides documentation for the protocol used by the System Loader ROM in the STM32 parts, you should review that.
ST also has many examples of IAP (In-Application Programming), those might give you some ideas and a starting point.
Most of the complexity is not STM32 centric, what experience do you have writing loaders and doing firmware updates?
Posted on February 09, 2017 at 05:03
Thanks for the quick replay.I have basic knowledge on  writing loaders.
Dose any one have a custom booloader example which suits my requirement so i can modify that according to my requirement.
Max
What
Turvey.Clive.002
and
for details.
best regards,
Max
Please update the links of the documents mentioned above.
